hampster63
#1 Posted : Tuesday, June 30, 2009 8:04:37 AM(UTC)
hampster63
I only get the first fire up of the burner on my gas dryer after that burn off I see the igniter glow yet i have no burn. I have tested the thermal fuse and that is good. I could not find anymore info on what to test next and what readings I should have. any suggestion would be great.
thank you
#2 Posted : Tuesday, June 30, 2009 1:11:58 PM(UTC)
The first thing I would do is replace the gas valve coils (#13 & #14 on the diagram)
- The part number for the coil kit is AP3094251
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL LGQ7030KQ0 | AppliancePartsPros.com
hampster63
#3 Posted : Thursday, July 2, 2009 4:53:19 AM(UTC)
hampster63
Thank you Gene, I installed both coils and the dryer is running just fine. Again thank you for you wonder advice.
Dave
#4 Posted : Thursday, July 2, 2009 3:10:25 PM(UTC)
You are welcome Dave. I'm glad you were able to fix it.
Guest (4)
