I am trying to replace the secondary water valve which broke over the winter. I have the part but the new part is a little different and I forgot to notice which wires went where and which tubes whent where. The unit has a brown valve and a blue valve. Which wiring harness color goes to which valve. Does anybody have a schematic of the location of the water tubes and the wire harnesses?
I have the same problem. I need a schematic showing where the water lines connect and go to. Originally Posted by: jameskearns  I am trying to replace the secondary water valve which broke over the winter. I have the part but the new part is a little different and I forgot to notice which wires went where and which tubes whent where. The unit has a brown valve and a blue valve. Which wiring harness color goes to which valve. Does anybody have a schematic of the location of the water tubes and the wire harnesses?
http://www.searspartsdirect.com...=06&prst=&shdMod= If you go to this site it will give you the schematic and the color codes on the water lines. You just put your cursor on the schematic and it enlarges whatever you have it on. I was able to get the part I bought from AppliancePartsPros to work using this schematic. I hope you didn't cut off the water lines. The colors are pretty faint and are colored rings printed on the water line about 3/4 inch from the end of each line.
