BillWat
#1 Posted : Tuesday, June 30, 2009 2:51:14 PM(UTC)
BillWat
This may be two problems, because one by one, the burners stopped lighting, even though they clicked. Sometimes that would resolve if I cleaned them, but not always. In fact, I could clean the Rt rear, put it together, and the Lt front would start to light again! But eventually no amount of cleaning helped.
Now, however, they do not even click. There is power to the unit, evidenced by the oven working and pre-heating indicators working.
Do I need 4 igniters? Do I need something else, even?
Thanks for being here.
BillWat
#2 Posted : Tuesday, June 30, 2009 5:18:30 PM(UTC)
BillWat
The burners will light with a match. Just no ignition. The broiler and oven light without problem.
BillWat
#3 Posted : Wednesday, July 1, 2009 7:37:54 AM(UTC)
BillWat
Any light anyone can shed?
Dan O.
#4 Posted : Wednesday, July 1, 2009 11:46:00 AM(UTC)
Dan O.
Quote:
Now they do not even click.
The 'clicking' originates at the spark module (see the following link).
LINK > GE JGBP30BEA4WH Spark Module
There is an electrical switch (see the following link) on each of the burner valves that switches power to the module when the burner valve is turned. When powered the module clicks.
LINK > GE JGBP30BEA4WH Surface Ignition Switch
It would be unusual for all of those switches to have failed time so there may be a problem with the spark module itself. If power was getting to it when any of the burners was turned on but it was not clicking, the spark module would likely be defective and need to be replaced.
That could be due to the spark module getting 'weak' with age.
That could just be coincidence or there might also be a problem with the burner's spark electrodes or their insulators. Neither of those should prevent the module from clicking though.
LINK > GE JGBP30BEA4WH Burner Spark Electrode
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
BillWat
#5 Posted : Wednesday, July 1, 2009 1:10:00 PM(UTC)
BillWat
This sounds very logical and is much apprieciated. I guess I would first want to replace the GE JGBP30BEA4WH Spark Module Can you tell me which exploded diagram features this, and whether it is obvious how to get it all apart. I am capable of almost any type of repair, but have never popped the top on this stove at all.
Thank you
Dan O.
#6 Posted : Wednesday, July 1, 2009 10:47:05 PM(UTC)
Dan O.
It is shown in "Control panel & cooktop" illustration, item # 110. Whether that is actually where it is located on your range I have no idea.
Quote:
is it obvious how to get it all apart.
I wouldn't call it "obvious". That isn't really the purpose of the parts illustrations.
JMO
Dan O.
=D~~~~~~
BillWat
#7 Posted : Thursday, July 2, 2009 4:03:05 AM(UTC)
BillWat
I see it in the illustration. And I probably wasn't clear enough, saying, "is 'it' obvious"--I guess I meant does anything jump up and bite you when you are trying to get the control panel appart, or does unscrewing the end caps lead to a straightforward dissasembly. I am going to try it, and hope that it goes alreight.
Dan O.
#8 Posted : Friday, July 3, 2009 10:01:36 AM(UTC)
Dan O.
I'm afraid I do not know how access to the control console components is achieved on your model, sorry.
There's shouldn't be anything spring loaded, no, and it shouldn't just fall apart once opened either.
Good luck! Let us know how you make out.
Dan O.
=D~~~~~~
