SJS
#1 Posted : Monday, December 31, 2007 2:55:24 PM(UTC)
SJS
When starting the oven, I can smell gas then a mini-explosion with a whump sound. The broiler works fine when starting. I think that the igniter needs replaced. I know that I can do the replacement with some help on the type of part needed and some basic instruction.:confused:
#2 Posted : Tuesday, January 1, 2008 2:50:16 PM(UTC)
Yes, you were right. To solve the problem the bake igniter has to be replaced.
- The part number for the igniter is AP3119495
- Here are the break down diagrams for the Whirlpool range Model SF387PEYN3
Good luck.
