morrison123
#1 Posted : Wednesday, July 1, 2009 2:52:05 PM(UTC)
morrison123
My Bosch condensation dryer just stopped heating up when it was drying, but the air still blows and it turns. Can I just buy a heating element to install to get the heat going again? Thanks!
sidfink43
#2 Posted : Thursday, July 2, 2009 2:47:10 PM(UTC)
sidfink43
Hi Morrison
Unfortunately, if you look at postings regarding Bosch on this Forum you see very little, because it is just not a brand which I (and I think others) are experienced with. I recommend you post on another Forum and see if you can get some help. Be sure to include your model number.
I would certainly try to get some troubleshooting advice,(and a service manual if you can get one) because in many cases with dryers it is not the heating element but thermal fuses/thermostats/thermistors which are the problem, and they cost a lot less than the heating element and are a lot easier to replace. You will want to rule them out before going with the element.
Sorry we could not do better for you, good luck.
