I have a water leak at the blue quick connector on my side by side. Does anyone know the part number for the connector? It appears it is a 5/16" line that allows removal of the freezer door. Thanks!
I can’t find the part number for the blue connector with the quick connects right off but the part number for a coupling that will work is WR2X8545. This is just a coupling with two nuts. Refrigerator repair guide
Now that I am at the shop I found the part number for the one with the quick connections WR02X10471. Either one will work so if you already ordered don’t worry.
