menlo
#1 Posted : Tuesday, June 30, 2009 8:28:38 PM(UTC)
menlo
Everything is working except when it end the spin cycle. I would like to replace the support pads but the springs are real difficult to unhook, is there a special tool for them? W[FONT=&quot]a[/FONT][FONT=&quot]sher's drive coupler and all looks great nothing broken rubber not worned. Aside from the support pads is there anything else that could be causing this problem?Maybe I did not get enough 'Sil-Glyde' between the brake coil spring and the inside of the drum. Is there another way to apply the grease to this area? [/FONT]
