Hello, I have an LG refrigerator, model lsc27910SB.
The ice tray is only filling up 4 of the 8 trays. This is causing us to always be low or out of ice. Is there an adjustment I can make to have the water run longer to fill the whole tray? I have opened everything up, but can not find it.
Also, the water comes out of the door very slowly. About 7 ounces in 20 seconds. The manual says it should do 7 oz. in 3 seconds.
I have checked my pipe, nothing is kinked. The valve where it is attached to the cold water supply is open all the way. The pipe is only about 10 feet long.
I have tried replacing the water filter too, but no luck.
Any help would be appricated, thanks.
A strainer before the inlet valve can get stopped up restricting flow of water. Flush it out while you have it disconnected.
