RVtrader
#1 Posted : Tuesday, June 30, 2009 3:41:38 PM(UTC)
RVtrader
Kenmore side by side started leaking water under the front of the unit everyday aorund a certain time. I found by opening the freezer door there was ice build up of about 1/2" and the water was running out becasue no more space to freeze. The coils in the back were red assuming this is a defrost process. This happens everyday- if I remember to bust the layer of ice out of the bottom everyday I'm good for about 2 days. If not I have water on the floor. Which componet is not working properly everything else is fine on the freezer except for our new water leak.
Drags1998
#2 Posted : Tuesday, June 30, 2009 4:27:23 PM(UTC)
Drags1998
You will have to clean out the defrost drain tube in back of the rear wall of the freezer!!!! Theres a 1/2" hole in the center that is plugged up.:)
