Help..my washer overfills on all settings. Is this a timer problem? I have the timer switch off and can't find diagram to put back together.
Hire a Pro before you get in ANY deeper!!!!!:D
Unplug the machine. Reconnect the timer and reinstall it (if you removed it). Plug the machine back in and select any cycle to start fill (select small load). As it begins to fill, unplug the machine. If it continues to fill after it's unplugged, turn off the water supply and replace the water inlet valve.
