wrestlingmom
#1 Posted : Monday, December 31, 2007 8:05:57 AM(UTC)
wrestlingmom
The burner component on my JennAir stove isn't working. I'm wondering if this is a common problem. I purchased my stove from Sears and they will send out a technician to look and repair. If I only need a new burner unit then I will skip the technician step and order a new unit. The oven works fine and the side of the stove with the grill unit works fine. I have a JennAir Model SVE47100 (Sears parts and service gave me the model number of 629SVE47100W)
About a year ago I dropped a skillet on the stove top. It flashed red and since then the little green light indicating the burner is on is always on even when the knob is turned to off and unit is actually off. Both burners still worked.
Last week my daughter banged a skillet on the burner unit. The front burner flashed. Both burners worked for a while. The back burner stopped working first. Then the front started acting up. At first it would work one time and not the next. Finally the front one stopped working altogether although when you would turn it on it would get red and start to heat up then would quit. Now we get nothing.
Thanks for any help/reccomendations you can give me.
