crappieman
#1 Posted : Tuesday, June 30, 2009 9:20:29 AM(UTC)
crappieman
i have a litter water in the bottom of the refrigerator would this come from my freezer seting being to hight or to low or is this normal any help would be great
woodchuckie
#2 Posted : Tuesday, June 30, 2009 11:45:01 AM(UTC)
woodchuckie
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
crappieman
#3 Posted : Tuesday, June 30, 2009 1:35:27 PM(UTC)
crappieman
i turn the refrigerator around there is a pandel at the botton is that were the drain tube is and how to i get to the top of the dran tube there no pandel at the top help!!
