kg101370
#1 Posted : Monday, June 29, 2009 6:33:54 PM(UTC)
kg101370
The baffles loose on my dryer. How do I get the top to open. O don't see any clips.
sidfink43
#2 Posted : Wednesday, July 1, 2009 7:28:23 AM(UTC)
sidfink43
Hi KG
It is an easy process that first involves removing four screws in the door area, but what the heck, the service manual can tell you a lot better than I can, so here it is.
http://www.servicematters.com/m...ibrary/docs/16023110.pdf
It should also help with your baffle problem.
Good luck, let us know if you need more help
