thescholar
#1 Posted : Monday, June 29, 2009 2:58:08 PM(UTC)
thescholar
My dishwasher is getting stuck in the same exact two cycle every time it is operated. The timer wheel gets stuck in the 7 and 9:30 positions. The timer has been replaced with new ones three times. Also replaced has been the thermostat, temp booster, sensor and the logic board. I have ServiceCare through SCE&G and they are the ones doing this while I stand there and watch. They have been working on this issue for 7 months now.
Can anyone offer advice as to the problem (Not cracks on Service Care. Of course there will be at least one moron that will have a crack)?
Drags1998
#2 Posted : Monday, June 29, 2009 3:13:51 PM(UTC)
Drags1998
Turn your HOT water temp UP to at least 140 degrees, If its not that hot, It will stall the timer until it is!!!!!!!!! That s all I can think of.:)
