AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Inglis heavy duty drier with no heat no model number
all the manual says is about fuses, how do I get the back off to check this? the drier drum spins but there's no heat thanks
Well, difficult to say without a model number, but generally this is a Whirlpool dryer sold under the Inglis name. If it is a U.S. model you should be able to take off the back by unscrewing it and removing it, which will expose the fuses.
If this is not a U. S. model then you may need some other instructions.
If you need addtional info try to find the model number (inside the door, on the back of the console??) and post again.
Good luck.
Dryer Repair
