2 Pages12>
dangohlke
#1 Posted : Monday, June 29, 2009 10:58:53 AM(UTC)
dangohlke
My Maytag propane gas dryer will call for heat , the igniter will get hot (red), the gas will flow, the gas will ignite, and then in about 2-5 seconds the gas flow will cut off. If the dryer is left on, it will spin and cycle through this sequence repeatedly, but never really get hot.
What needs to be done to fix this? Thanks.
#2 Posted : Monday, June 29, 2009 7:07:20 PM(UTC)
The first thing I would do is check the vent all the way through the outlet and all air ducts inside the dryer, including the blower housing and the blower wheel.
Here are the breakdown diagrams and Replacement parts for MAYTAG LDG8624AAE | AppliancePartsPros.com
bcdunmore
#3 Posted : Wednesday, July 18, 2012 12:57:23 PM(UTC)
bcdunmore
Gene:
Dryer is as clean as a whistle, including air ducts and vent pipes. Internal blower parts are also clean. Any more ideas?
Simon / APP Team
#4 Posted : Wednesday, July 18, 2012 1:39:45 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Replace the control coils kit Part number: 279834
Part number: 279834
Here are the breakdown diagrams and Replacement parts for Maytag LDG8624AAE DRYER- GAS | AppliancePartsPros.com
Thank you. Post the results.
Simon.
bcdunmore
#5 Posted : Wednesday, July 18, 2012 4:32:56 PM(UTC)
bcdunmore
Originally Posted by: bcdunmore Go to Quoted Post
Gene:
Replaced coils and flame goes out in less that one minute
Simon / APP Team
#6 Posted : Wednesday, July 18, 2012 9:51:03 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What do you mean: "the flame goes out"? Does it ever ignites again?
Remove the vent hose from the dryer and run one load of laundry. See if that makes any difference.
Thank you.
Simon.
bcdunmore
#7 Posted : Thursday, July 19, 2012 5:16:45 AM(UTC)
bcdunmore
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Thank you.
Simon.
Simon:
Removed hose and ran dryer, flame went out while all else kept runnung. Replaced the coils and the flame still goes out after less that one minute. All else keeps running. Flame does not re-ignite.
bcdunmore
Simon / APP Team
#8 Posted : Thursday, July 19, 2012 10:08:42 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Does the ignitor cycling on and off with out the flame? If it does - replace the gas valve.
If not - check the flame sensor and hi-limit thermostat (both on the burner tube).
Use the time dry not the auto, does it make any difference?
Simon.
bcdunmore
#9 Posted : Monday, July 23, 2012 6:26:01 PM(UTC)
bcdunmore
Hi.
Simon.
Simon
Replaced the coils and then the flame sensor. Flame still goes out aft less than one minute. Tried the time dry and auto dry, neither mattered. Any other options?
MayTech
#10 Posted : Monday, July 23, 2012 10:21:00 PM(UTC)
MayTech
Make sure the flame is being pulled through the burner assembly, if it's just going up and hitting the top of the burner box then you have an airflow issue. Check your blower wheel, if it spins on the shaft without turning the drum then it's worn out and will need replacing.
None of this may be it but i didn't see any mention of it yet and just trying to offer some other things to check. good luck. let us know what you find.
Guest (5)
2 Pages12>
