amanascott
#1 Posted : Saturday, December 29, 2007 11:40:25 AM(UTC)
amanascott
help! when my wife recently cleaned our stove she removed the push-button control knobs to the control panel. when she replaced the knobs the plastic female receive pins snapped on 3 of the control panel locations. i removed the control panel and ordered a replacement thru appliancepartspros, installed the new panel and tried everything successfully. i set the oven to bake at 300 and the stove worked fine. mind you this was christmas morning and we had 20 people en route for the holiday dinner. 2 hours later we cooked the christmas dinner for 2 1/2 hrs. without any trouble. 5 hours later with the oven not in use i was on the couch in the other room and the oven started non-stop beeping and flashing F-2. after searching online i found F-2 to indicate a faulty oven temperature sensor. i removed the sensor and measured the resistance at .69 ohms. is this faulty and by replacing will it solve the F-2 code on the control panel?
amanascott
#2 Posted : Sunday, December 30, 2007 3:35:46 PM(UTC)
amanascott
any help????
#3 Posted : Monday, December 31, 2007 2:12:45 PM(UTC)
The resistance across the oven temperature sensor wires suppose to be about 1100 Ohms at the room temperature.
If you got a different reading then the oven sensor has to be replaced.
Also check the sensor wires and the connection at the control board.
- The part number for the oven temperature sensor is AP3998148
- Here are the break down diagrams for the Amana range Model AGDS902E
Happy New year!
amanascott
#4 Posted : Monday, December 31, 2007 2:53:27 PM(UTC)
amanascott
thanks for the tip. that's the info the parts dept. thought could be wrong. i'll try a new ovn temp. sensor.
