looked @ a schematic for this unit and cannot find the water valve I want to replace. have already replaced the modular unit on the icemaker, jumped the terminals and water flowed in the unit but is not filling with water to make ice in a normal cycle.
please advise.
thanks, claytonjohn
If the water valve worked when you jumped the terminals then the ice maker is the problem.
