3 Pages<123
kirkdj
#21 Posted : Friday, June 19, 2009 5:35:27 PM(UTC)
kirkdj
Originally Posted by: kirkdj Go to Quoted Post
you could use the same troubleshooting technique I did and find out which key is stuck
also not sure you can repair it, I think you need to verify that is the problem and you'll probably have to replace the keypad, which comes with that top plastic panel, mine was $136....
#22 Posted : Saturday, June 20, 2009 2:13:25 AM(UTC)
I agree with kirkdj
As far as I know there is no reliable way to fix a stuck key.
kirkdj
#23 Posted : Sunday, June 28, 2009 8:54:56 AM(UTC)
kirkdj
The new keypad arrived and once installed & I even used the old circuit board.....problem solved, worked like a champ.
Thanks Denman!!!! :D
I know where to come now for appliance help!! Thanks Again! :)
3 Pages<123
