Hi, Just installed an ex display Bosch dischwasher sms63e02gb but it won't intake water. It has aquastop device and you can hear come clicks from switches/electrical devices but no water come in. Once start is pressed, same noises but after 3 s error code 23 "E.23" is displayed. Valve at the end of intake pipe seems ok, i have read of float dispositive stuck in wrong position but don't know where to check. any idea of the probem? thanks, loas
Originally Posted by: loas Hi, Just installed an ex display Bosch dischwasher sms63e02gb but it won't intake water. It has aquastop device and you can hear come clicks from switches/electrical devices but no water come in. Once start is pressed, same noises but after 3 s error code 23 "E.23" is displayed. Valve at the end of intake pipe seems ok, i have read of float dispositive stuck in wrong position but don't know where to check. any idea of the probem? thanks, loas I had the same problem with my Bosch dishwasher. It was the water inlet valve. I installed it myself without much difficulty. It's a $35 part.
