Lighting recently struck near our house and our side by side GE Fridge and freezer is not working properly. The fan is blowing warm air inside the freezer and fridge. I replaced the run capacitor, start relay and the overload and still nothing. Initially there is a click noise once it's plugged in. The display panel on the front seams to be working fine, displays temp, beeps, etc. The light inside fridge is also ok. The compresssor is not turning on nor is the fan behind the fridge only the one inside the unit is blowing. Thanks in advance for your help!
The mother board did the trick all is working perfect again. Thank you!!:)
