dixieg3gs
#1 Posted : Saturday, June 27, 2009 7:45:13 AM(UTC)
dixieg3gs
My front load machine acts like it is unbalanced with every load and sounds like an aircraft landing on my house.
#2 Posted : Saturday, June 27, 2009 8:38:28 AM(UTC)
Spin the basket and see if you can feal bad bearings. If so, you will need to take the tub apart and replace the bearings, a big job.
magician59
#3 Posted : Saturday, June 27, 2009 8:39:54 AM(UTC)
magician59
Sounds like the spinner bearing needs to be replaced. This can be done by you if you're quite mechanically inclined. Otherwise, it's about a $1000 repair.
