2 Pages12>
Barry White
#1 Posted : Wednesday, December 12, 2007 3:51:46 PM(UTC)
Barry White
I need to know how to replace the inside oven door glass on my Dacor oven. I've got the part but am not sure how to remove the old glass and replace it. Any suggestions ? Thanks in advance for any info you give.
#2 Posted : Wednesday, December 12, 2007 5:48:34 PM(UTC)
Attached you find the Oven door break down diagram.
File Attachment(s):
Oven door.doc (73kb) downloaded 262 time(s).
Barry White
#3 Posted : Sunday, December 16, 2007 10:07:09 PM(UTC)
Barry White
Gene - thanx for the oven door diagram. I'll give it a go.
#4 Posted : Sunday, December 16, 2007 10:29:44 PM(UTC)
Keep me updated, please.
Barry White
#5 Posted : Saturday, December 29, 2007 5:28:06 PM(UTC)
Barry White
Gene,
Thanx again for the detailed expanded diagram. It sure helped. I got the old part out ok and went to install the new glass unit only to find it defective. One of the mounting tabs on the frame of it was missing. I just removed the frame of the old one and used it. Took a bit more time but it all worked out in the end. Oven now works great.
Barry
#6 Posted : Saturday, December 29, 2007 5:47:02 PM(UTC)
I'm glad you were able to fix it.
Happy New year!
Barry White
#7 Posted : Monday, December 31, 2007 5:59:28 PM(UTC)
Barry White
Thanks again for your help. Happy New Year to you and yours as well!!
wkh
#8 Posted : Friday, December 19, 2008 9:58:25 AM(UTC)
wkh
it seems I want the glass assembly
do i need to take off the door from the oven to gain access to the screws to dissassemble? should i replace the outside metal gasket at the same time or can i put it back?
thanks
#9 Posted : Friday, December 19, 2008 11:30:04 AM(UTC)
wkh,
What is the complete model number of the oven? The oven door always has to be removed for any repair.
awhittak
#10 Posted : Monday, November 23, 2009 9:29:24 AM(UTC)
awhittak
How do you remove the oven door on the CPS130
Guest (4)
Oven Door Glass Repair (Oven Repair (including Ranges and Cooktops))
by jvkonieczka@prodigy.net 4/27/2011 11:49:40 AM(UTC)
2 Pages12>
