keefus
#1 Posted : Friday, June 26, 2009 7:38:10 AM(UTC)
keefus
recently i have been seeing clean water appear at the bottom of my refrigerator every day. it is clean, no odor and none of the goods are leaking not sure what this could be??
#2 Posted : Friday, June 26, 2009 8:25:17 AM(UTC)
Sounds like the drain tube for the defrost water is plugged.
Replacement parts for MAYTAG MTB1954ARA | AppliancePartsPros.com
Here is a service manual
http://www.servicematters.com/m...ibrary/docs/16008248.pdf
Remove the front kick plate and check the drain tube at the tray to ensure it is not plugged at the end by dust etc.
Looks like it drains into the top of the fresh food section and then down the tube to the drip tray. You will have to get to the tube and blow it clear. A compressor set a a lower pressure, a turkey baster with some water or even a straw may help you do this.
Once clear it is a good idea to flush it with a 10% bleach solution to kill the crud that likes to grow in it. A turkey baster does this nicely.
