belt broke found tension bar in bottom of unit with belt seema to me there is no way tuo thread a new belt threw the tensioner half moon with teflon strip do i have to change that out to the new still with the roller:mad:
Replace the idler glider with the idler assembly with a roller, part # Part number: 691366
. The new belt, part # Part number: 341241
should come with installation picture, just ask when you order it.
I tried replacing the "teflon tensioner" with the 691366 idler pulley and the dryer was noisier. Put the teflon part back in and quiet again. You may experience the same thing.
You probably have a bad/stretched belt!!
ordered the one with roller and new belt kit my tensioner with tef guide was in bottom of unit off mount i dont see how it is routed threw guide is there any were to see that dia. with ome guide
The belt was brand new. The pulley came with the kit and so I thought I'd try it at least. Even put 3-in-1 oil on the pulley shaft before installing.
how does belt feed threw that teflon guide
With the grouved side of the belt against the drum, there is only one way to route the belt thru the gluide or roller to get proper tension on the belt.
