The ice maker stopped making ice. I connected power directly to the selenoid and water started coming out to in the ice maker. I removed the ice maker, the connector has white, black/white, brown and green wires. I connected power directly to the white and the black/white wires and the blades that pushes the ice into the container started turning. The brown wire matches the the brown in the selenoide (I assume powers the selenoide) when the cycle calls for it. My guess the problem is in the eye that stops the production of ice when the canister is full, the on/off switch is part of the board that controls the canister eye. I don't have an electric diagram. Any ideas?:confused:
