matthecatt
#1 Posted : Thursday, June 25, 2009 11:59:44 AM(UTC)
matthecatt
Will not clean the dishes in all the cycles and their is little water residue.
#2 Posted : Thursday, June 25, 2009 7:44:31 PM(UTC)
Remove the lower spray arm and the pump cover. Remove the pump filter and the rinse arm assembly (#6 & #7 on the diagram) and clean them using a white vinegar and a tooth brash.
Here are the breakdown diagrams and Replacement parts for MAYTAG DWU9202AAB | AppliancePartsPros.com
matthecatt
#3 Posted : Saturday, June 27, 2009 10:09:01 AM(UTC)
matthecatt
Thanks Gene,I'll give that a try and let you know what happens.
With much gratitude,
Matt
Guest (4)
