smartin1019
#1 Posted : Thursday, June 25, 2009 1:37:43 PM(UTC)
smartin1019
How do I get into the mechanism that controls the ice maker door. When I remove the plastic water collection plate I don't see any screws. Under that plate while it moves a small amount I don't see how it would come out. Do I have to remove the inside door panel on this model. Thanks Martin
Drags1998
#2 Posted : Thursday, June 25, 2009 2:45:38 PM(UTC)
Drags1998
You pop off the Touch-pad and there 4 screws under it, The solonoid for the flap is rusty, Take it all apart and clean up the rust, put a LITTLE lube on the plunger and put it back together!!!!!!!!!:)
smartin1019
#3 Posted : Thursday, June 25, 2009 6:58:46 PM(UTC)
smartin1019
What is the trick to getting the touch pad off. feels as if something is holding it on Thanks Martin
smartin1019
#4 Posted : Friday, June 26, 2009 7:59:58 AM(UTC)
smartin1019
Figured it out. The solenoid and shaft were a mess. Had to clean with sand paper. seem to work fine. Thanks Martin
