WALJ
#1 Posted : Sunday, June 21, 2009 2:45:59 PM(UTC)
WALJ
I just completed changing the safety valve and now I can not adjust the flame, It continues to burn yellow even with the air control open all the way. My stove uses propane and the valve P/N is WC5308009419 where can I find out if this is the right part forn my stove. I want to make sure it is not one for a nature gas stove.
Dan O.
#2 Posted : Sunday, June 21, 2009 6:47:44 PM(UTC)
Dan O.
The correct valve for your range is Frigidaire part number 5308009419, Appliance Parts Pros # AP2152452.
Quote:
I just completed changing the safety valve... My stove uses propane
Than the valve will likely need to be converted just as the original one was when the appliance was first installed. Check the owner's manual or installation instructions for how that is done.
JFYI. Gas range parts are often shipped from the factory set for natural gas. If to be used with propane, they will usually need to be converted.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
WALJ
#3 Posted : Thursday, June 25, 2009 5:49:53 PM(UTC)
WALJ
Thanks DanO, After I posted my request, I keep searching the web on the valve in question and I found a sight that told me about adjusting the orfice thanks for the help
hawaiicarl
#4 Posted : Tuesday, December 1, 2009 2:19:26 PM(UTC)
hawaiicarl
Aloha DanO,
I have the same problem with the yellow flame on my Tappan 30" gas range. It has been converted for propane and all the stove-top burners work OK, but in the owner's manual it says to adjust the orofice until the flame has the correct size and color - I have attempted this but even when the orofice is closed as much as possible too much gas is still coming out.
Model # TGF 317 ESC
Ser # VF6 1856320
Do I need to order a different safety valve or can the orofice be adjusted to get the correct flame? Please help.
Mahalo, Carl
Help...A Gaffers & Sattler Oven Safety Valve is desperately needed. (Oven Repair (including Ranges and Cooktops))
by AdrienneInNY 11/13/2008 7:41:56 PM(UTC)
