WHR
#1 Posted : Thursday, June 25, 2009 1:29:28 PM(UTC)
WHR
My side by side Kenmore Coldspot has water accumulating in the bottom or the freezer floor section. Any ideas on what is causing it and repair of the same? Thanks. Wayne
woodchuckie
#2 Posted : Friday, June 26, 2009 6:21:07 AM(UTC)
woodchuckie
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
WHR
#3 Posted : Friday, June 26, 2009 6:48:11 AM(UTC)
WHR
thanks. You are correct. It cleared it up. TY
Kenmore Coldspot - Water filter will not fill, no H2O or Ice (Refrigerator & Freezer Repair)
by rncotton 8/16/2023 8:00:22 AM(UTC)
Kenmore Coldspot trips GFI, Occasionally (Refrigerator & Freezer Repair)
by wdeagle 8/10/2023 7:48:24 AM(UTC)
Water not working on kenmore coldspot 106.5942280 (Refrigerator & Freezer Repair)
by Alsassin 7/19/2023 3:26:57 PM(UTC)
Kenmore Coldspot Model 106 not cooling (Refrigerator & Freezer Repair)
by wdeagle 7/2/2023 8:54:15 AM(UTC)
Kenmore Coldspot model 106.9555611 Water Dispenser (Refrigerator & Freezer Repair)
by reynolpe 2/14/2023 1:40:10 PM(UTC)
kenmore coldspot 106.54573300 (Refrigerator & Freezer Repair)
by jncin209 9/19/2022 2:49:28 PM(UTC)
kenmore coldspot ref (Refrigerator & Freezer Repair)
by Guest 7/18/2022 7:48:27 AM(UTC)
Kenmore coldspot 106.58943802 water works much better without old or new filter (Refrigerator & Freezer Repair)
by Guest 4/12/2022 5:33:23 PM(UTC)
Kenmore coldspot 106.58943802 water works may better without old or new filter (Refrigerator & Freezer Repair)
by Guest 4/12/2022 5:31:27 PM(UTC)
Technical data sheet for Kenmore Coldspot 106.74982401 (Refrigerator & Freezer Repair)
by GardnGirl 11/11/2021 9:15:13 AM(UTC)
Kenmore Coldspot 106 dripping ice filler (Refrigerator & Freezer Repair)
by MuskyHntr 9/11/2021 10:27:31 AM(UTC)
Kenmore coldspot refrigerator 10656989601 (Refrigerator & Freezer Repair)
by Guest 8/5/2021 12:19:48 PM(UTC)
Kenmore Coldspot 106.58953800 (Refrigerator & Freezer Repair)
by Guest 6/5/2021 8:53:25 PM(UTC)
Kenmore coldspot 106 ice trap or flap not closing completely and is leaking (Refrigerator & Freezer Repair)
by Guest 6/4/2021 1:50:15 AM(UTC)
Kenmore Coldspot 106 (Refrigerator & Freezer Repair)
Belarus ttinidaho 3/1/2021 2:16:55 PM(UTC)
