esb41
#1 Posted : Thursday, June 25, 2009 12:46:00 PM(UTC)
esb41
Oven working fine, until I used Easy Off to Clean ( I Did NOT use Oven Clean Cycle). After use of Easy Off, now oven will not heat, and thermostat only shows clean light coming on, no matter where thermostat set. Thermosat shows temp settings, but oven Not Heating. ( I did spary Easy Off on slot where oven clean latch comes out of oven door frame. )
What part do I need to replace?
EB
#2 Posted : Thursday, June 25, 2009 8:13:12 PM(UTC)
All major manufacturers do not recommend to use any kind of an oven cleaners for self clean ovens. Very possible the Easy Off caused short and/or damage to the door latch switches and even to the control board.
Check the switches on the door latch for continuity and inspect wires. Post the results.
Here are the breakdown diagrams and Replacement parts for GE JBP26WY3 | AppliancePartsPros.com
Dan O.
#3 Posted : Thursday, June 25, 2009 8:52:19 PM(UTC)
Dan O.
I was also thinking the oven temperature sensor might be a possibility if the control is displaying temperatures and if it 'thought' those where high enough might indicate to the control a self clean cycle was in progress?
LINK > How do I check an oven temperature sensor?
LINK > GE JBP26WY3 Oven Temp. Sensor
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
