Roddy1
#1 Posted : Tuesday, June 23, 2009 8:25:01 PM(UTC)
Roddy1
Its a front loading Fridgidaire Gallery was making loud squeaking noise during final spin. It threw the belt a couple times now wont final spin at all. Bearings? Which ones motor or drum...is there drum bearings. What you guys thinks. All info will help. Thanks fellas
Ryan
sidfink43
#2 Posted : Thursday, June 25, 2009 12:21:30 PM(UTC)
sidfink43
Hi Roddy
An educate guess without the model number is that it is probably the rear drum bearings, which seem to fail regularly on Frigidaire front load washers. The bearings are not sold separately, you will have to replace the rear half of the tub.
This is a fairly expensive part, and a somewhat difficult repair, but if you want to attempt it post a model number and let's see what we can do for you.
Thanks and good luck.
