lower heat element not heating we replaced it and it dose not work im afraid to buy a control board its a 125 dollars it may not be problem the broiler ele element works fine
Quote:lower heat element not heating we replaced it and it [did not help] The appliance would have to be checked out to determine the cause with certainty but I don't see much in your model that could prevent just the bake element from functioning besides a defective element, a malfunctioning electronic control or some sort of problem in the range's wiring between them. LINK > Kenmore 665.95781000 Electronic ControlQuote:a control board is 125 dollars BTW. That is less than 1/2 the price Sears looks to be charging for the same part ($289)! :eek: JMO Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
my oven will not heat up at all on any setting. i did a self cleaning and ever since then my oven will not heat up! any suggestions on what it might be?:confused:
Please start a brand new message of your own for your problem and be sure to include the brand name and exact model number of the appliance in question and I'm sure someone will try to assist you. Use the button at the top of the page that looks like this:  JMO Dan O.
