The new design of the motor coupler has a metal sleeve on the triangular pieces. There seems to be something designed in the metal sleeve that keeps the new part from mounting all the way onto the hub. It goes about halfway onto the sleeve, but won't go further. Is this how it is supposed to fit now - or do I have a defective replacement ?
i use a3/8 socket extension +tap coupler with hammer till flush with shaft ,some tech apply a little grease in coupler
