Hi folks,
Have a Frigidaire Gas range that works fine except the panel clock won't stay on. If I depress the clock button (to set it) it will light but will go out after maybe 5 seconds. Tried cutting power to the range and 12:00 will flash but won't stay lit.
Anything I can do here besides replacing the clock/timer part? Looks like it's about $140.
Thanks.
From the bottom of page 9 of the owner's manual (in highlighted text BTW): Originally Posted by: Frigidaire Owner'
Note: To turn the time of day display OFF or ON in the display press and hold <clock> for 15 seconds (the control will beep once) and then release.
JFYI Dan O. www.Appliance411.com The Appliance Information Site=D~~~~~~
Thanks Dan. Now that you've pointed it out I do see that in the manual. Missed it completely at first. That was a nice inexpensive repair! Much appreciated.
Paul
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Yes that works. Ours has been off since the last time we did the deep clean cycle. We decided to live without it rather than spend money. Today I’m having a sleep problem so playing with my phone and decided to research the problem. Voila, there it was , 1st search and it’s fixed. Thank you so much. We’ll see in a few hours if my wife even notices that the clock is on again. I’ll bet that she will. And she will say thanks too.
