Hugh
#1 Posted : Saturday, December 29, 2007 4:25:00 AM(UTC)
Hugh
The Oven does not Bake Properly, I replaced the Bake Element with a New one (this is a Hidden Element in the Floor) but no power to it with Bake Selected only 1/2 of the broil (Double Element) lites Can't find any fuses No Power Coming from the (9782437) Power Board I don't have a Wiring Diagram so it makes the job of tracing very Hard Plus I don't want to Just Purchess this Board (@ $250.00) if it is not the Trouble :) HELP!!!:confused:
misterfixall
#2 Posted : Saturday, December 29, 2007 7:49:51 AM(UTC)
misterfixall
if there is not power of 110 volts coming from bake terminal on board to ground or neutral when oven is turned on to bake .i woud say board is problem. check to see 220 volts coming out of line 1+line 2 on board ,be carefull not shock yourself
no power to bake element in top oven (Oven Repair (including Ranges and Cooktops))
by rnash 6/13/2013 3:12:06 PM(UTC)
