timchi29
#1 Posted : Tuesday, June 23, 2009 3:25:32 PM(UTC)
timchi29
I have a Whirlpool Refrigerator that water leaks from the freezer through the vents. I took apart the freezer and there was ice in the pan and in the drain. I flushed out the line and everything was good for a month and know same problem. I have been doing this every month or so. Any suggestions?
Thanks,
timchi29
#2 Posted : Tuesday, June 23, 2009 3:49:45 PM(UTC)
timchi29
I just would like to add that I found other posts that have this problem, but it keeps on happening.
woodchuckie
#3 Posted : Tuesday, June 23, 2009 3:52:00 PM(UTC)
woodchuckie
Try a bleach solution in the drain to kill any mold etc. that may be stopping it up. Watch it drain to be sure it all drains out and doesn't leave any to freeze and start stopping it up again.
timchi29
#4 Posted : Tuesday, June 23, 2009 3:56:53 PM(UTC)
timchi29
I did that and it works good, then it freezes up and water start flowing again. The bottom of the freezer, including the pan accumulates ice.
timchi29
#5 Posted : Wednesday, June 24, 2009 8:48:02 AM(UTC)
timchi29
Any thoughts?
Guest (4)
