I am have having two fault codes on my washing machine F-21 and F-33. I have had this problem with only the F-21 code before but the filter was dirty, this time I,ve checked the hoses, filter, and the pump is turning but water is draining out the tub and its not running up the drain line. When you run a cycle it runs fine until it tries to drain. So its gives me the F-21 code then I drain the water out of the filter and it will continue cycle but then gives me the F-33 code.
I would pull the pump and check the impeller area for foreign objects. If ok, I would change the pump AP4308966
Originally Posted by: richappy I would pull the pump and check the impeller area for foreign objects. If ok, I would change the pump AP4308966 I appreciate the reply and I will do just that.
