this washer makes a loud vibration noise at times when it is draining .could the pump be plugged with something. is there any cleanouts in the pump area that needs to be checked
Does it spin at that time?
Originally Posted by: Gene Does it spin at that time?
Gene. yes it spins at that time . I also think that it is pumping water out also.
Originally Posted by: Gene going to check pump today
