| » Maytag Washer Leak |
| By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use. |
Model Number: MAH4000AWW Brand: Maytag Age: 5 - 10 years
I have been trying to repair a Maytag Front load washer. Model Number MAH4000AWW. I have water pouring out of the door. I have checked the water valve....checked fine. I have checked the pressure switch...checked fine. I am lost at what to do next.
You probably have figured out your problem by now, however, just in case you are still dealing with this problem, here is how I solved mine: the hose filter screen, located in the cold water hose on the end attached to the washer, probably needs to be cleaned out! That's what I did with mine and it works with no leaking now.
Just so I wouldn't have to pull the washer all the way out from the wall in the future, I put a hose filter in the cold water hose on the end attached to the faucet. Keep those filters clean and the leaking will end! Bob N |
| Display Modes | |
| Kenmore washer oil leak | bobtx | Washer Repair | 3 | 05-11-2008 06:56 AM |
| washer leak | mjenk | Washer Repair | 2 | 01-28-2008 06:47 PM |
| leak on ge washer | shopower | Washer Repair | 2 | 12-09-2007 02:30 AM |
| oil leak from under ge profile washer | husker | Washer Repair | 0 | 10-14-2007 12:21 PM |
| Mah3000aww Maytag Neptune/bearings,leak | Tinamd | Washer Repair | 0 | 10-01-2007 10:30 AM |
