Stilltrying
#1 Posted : Monday, June 22, 2015 5:52:31 PM(UTC)
Stilltrying
I have a 27 year old Maytag stacker and have replaced $2-300 in parts over the years. In 2013 I did a major overhaul and replaced the (top part) Mounting Stem/Tub Seal Kit and the (bottom part) Tub Bearing Kit, among other stuff. It ran fine until 2015 when the useless Rubber Injector Valve went bad.
So I amazoned this valve and the plastic nozzle and installed both. Worked great until I ran a load - now the lower tub bearing leaks. Crazy thing is that it leaks more when the washer has a full load than when just a partial load.
Before I take it apart, again - anyone have suggestions ??
Much appreciation from a Dad with a daughter going to college in August
who does not want to spend $1500 plus on an new stacker.
thanks,
Still Trying
Other Successful Fixes:
Dryer Motor = 2009
Washer will not Agitate = 2013
Simon / APP Team
#2 Posted : Tuesday, June 23, 2015 9:35:56 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
There is nothing much you can do, but taking the washer a part and checking the condition of graphite rings at the mounting stem and the seal. If it's not grooved you probably may reuse it, but I would not take a chance. Wipe them clean, then pull up the seal and clean the surfaced of the tub around the opening, apply some liquid soap to the inner bottom portion of the seal and then push and turn the seal until it will be REALLY tight against the tub. Next take a Blue RTV silicon and squeeze a nice and even layer around the seal and slightly work it in using a finger (of your choice).
If you will do that water should not leak again for the long time.
Here is the Part number: AP4390013
You also may need a bearing kit but not likely because you have replaced it
recently Part number: AP4372971
Good luck.
Thank you.
Simon.
Stilltrying
#3 Posted : Friday, June 26, 2015 3:50:42 AM(UTC)
Stilltrying
Hi Simon,
Many thanks for your reply. What are the:
graphite rings at the mounting stem and the seal ?
Thanks,
Tom
Stilltrying
#4 Posted : Friday, June 26, 2015 3:55:58 AM(UTC)
Stilltrying
Also ...
With the rust towards the bottom of the shaft and the bumps / grooves on the shaft near the top
Would you say I have a premature Agitator shaft seal "ASS" failure ?
I guess the ASS is supposed to hug the shaft tightly and keep the
water from leaking down the shaft
I was finding small (BB size) hunks of grease in various places when I was taking it apart, and I can see small empty pockets inside the seal where I guess it was originally packed with grease.
I think the contact area for the Agitator Shaft Seal would be above the rust area and the bottom half of the black area
above the rust.
The Mounting Stem Tub Seal appears to be in good shape. <shown below>
Action Plan: sand the shaft a little to make it smooth and replace the Agitator Shaft Seal ?
Comments appreciated.
Tom
[IMG]http://images2.snapfish.com/232323232%7Ffp83232%3Euqcshlukaxroqdfv37832%3Enu%3D52%3C4%3E4%3A5%3E334%3EWSNRCG%3D383267584734%3Bnu0mrj[/IMG]
[IMG]http://images2.snapfish.com/232323232%7Ffp83232%3Euqcshlukaxroqdfv3%3A%3A55%3Enu%3D52%3C4%3E4%3A5%3E334%3EWSNRCG%3D383267584834%3Bnu0mrj[/IMG]
[IMG]http://images2.snapfish.com/232323232%7Ffp83232%3Euqcshlukaxroqdfv38262%3Enu%3D52%3C4%3E4%3A5%3E334%3EWSNRCG%3D3832686%3B7%3A34%3Bnu0mrj[/IMG]
Simon / APP Team
#5 Posted : Friday, June 26, 2015 11:59:37 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Your plan seems to be the only solution: the replacement transmission and agitator kit is no longer available :( The hard discs on the top of the boot seal and inside the mounting stem are the graphite rings.
Thank you,
Simon.
