Discuss
Roper washer won't spin
 in
Washer Repair
water empties from the barrel, but it doesn't spin. We have been able to turn it a bit in
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Roper washer won't spin
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 03-12-2008, 12:03 PM
cheapster cheapster is offline
Junior Member
cheapster is on a distinguished road
Default Roper washer won't spin
Model Number: RAS8445KQ0   Brand: Roper   Age: 5 - 10 years
water empties from the barrel, but it doesn't spin. We have been able to turn it a bit in the past and then get the machine to spin. However, last night, when you try to manually spin the barrel, it is VERY resistant. Then we did get it to spin but not as fast as it should. Also had to take out much of the load to spin well enough.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 03-13-2008, 11:06 AM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad clutch (#5 on the gear case, clutch and motor break down diagram).
- The part number for the clutch is AP3094537
Here are the break down diagrams for the Roper washer Model RAS8445KQ0
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 03-14-2008, 05:34 PM
allanrohnke@hotmail.com allanrohnke@hotmail.com is offline
Junior Member
allanrohnke@hotmail.com is on a distinguished road
Default
where is the model # on my roper washer
  #4 (permalink)
Old 03-15-2008, 10:22 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You can the model number under the lid.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Roper washer will not spin, agitate, pump litexp2 Washer Repair 14 08-07-2008 05:17 PM
Roper will not agitate and spin RDSandy Washer Repair 1 01-28-2008 04:32 PM
Roper will not agitate or spin RDSandy Washer Repair 0 01-26-2008 07:14 AM
Roper won't spin oznib Washer Repair 1 01-19-2008 01:43 AM
Roper washer will not spin rodtamara Washer Repair 0 11-12-2007 03:35 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
