water won't stop filling up:confused:
If the water will not stop filling even after you shut off the machine you have bad water valves and the assembly will need to be replaced.
If the water will stop when you shut off the machine either your hose from the water pressure switch to the tub is blocked or your water pressure switch itself is defectived.
