Discuss
Washer will not agitate
 in
Washer Repair
Washer went unused for about eight months. I went to use it recently but it will not agitate. It fills
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will not agitate
  #1 (permalink)
Old 02-20-2008, 01:46 PM
Junior Member
oogp1 is on a distinguished road
Default Washer will not agitate
Model Number: RAK2751KQO   Brand: Roper   Age: 5 - 10 years
Washer went unused for about eight months. I went to use it recently but it will not agitate. It fills up normally, but when it gets to the wash cycle it just makes a noise as if the motor is trying to turn but cannot. I tried turning the agitator by hand but it will not turn. I took off the agitator and give the spingle a gentle tap downwards but it still will not work. Please help. Ser# CM2702445 TYPE 157. Thank you.
Ads By Google
Related Models
Whirlpool RAL5144AG0
Whirlpool RAL5144AL0
Whirlpool RAL5144AW0
Whirlpool RAL5144BG0
Whirlpool RAL5144BG1
Whirlpool RAL5144BL0
Whirlpool RAL5144BL1
Whirlpool RAL5144BQ0
Whirlpool RAL5144BQ1
Whirlpool RAL5144BW0
Whirlpool RAL5144BW1
Whirlpool RAL6245AG0
Whirlpool RAL6245AL0
Whirlpool RAL6245AW0
Whirlpool RAL6245BL0
Whirlpool RAL6245BL1
Whirlpool RAL6245BW0
Whirlpool RAL6245BW1
Whirlpool RAM4131AL0
Whirlpool RAM4131AW0
Whirlpool RAM4132BW0
Whirlpool RAM4143AL0
Whirlpool RAM4143AL2
Whirlpool RAM4143AW0
Whirlpool RAM4143AW2
Whirlpool RAM5243AL0
Whirlpool RAM5243AL2
Whirlpool RAM5243AW0
Whirlpool RAM5243AW2
Whirlpool RAP5244AL0
Whirlpool RAP5244AW0
Whirlpool RAP7244DW0
Whirlpool RAR81K0
Whirlpool RAS1121EW0
Whirlpool RAS5133EQ0
Whirlpool RAS6233JQ0
Whirlpool RAS6233KQ0
Whirlpool RAS6233KQ1 Automatic Washer
Whirlpool RAS6233KQ2 Automatic Washer
Whirlpool RAS6233PQ0 Automatic Washer
Whirlpool RAS6233PQ1 Automatic Washer
Whirlpool RAS6233PQ3 Automatic Washer
Whirlpool RAS6233RQ0 Automatic Washer
Whirlpool RAS7133KQ0
Whirlpool RAS7133KQ1 Automatic Washer
Whirlpool RAS7133PQ0 Automatic Washer
Whirlpool RAS7133PQ1 Automatic Washer
Whirlpool RAS7133RQ0 Automatic Washer
Whirlpool RAS7133RQ1 Automatic Washer
Whirlpool RAS7133RQ3 Automatic Washer
Whirlpool RAS7133RQ4 Automatic Washer
Whirlpool RAS7233JQ0
Whirlpool RAS7233KQ0
Whirlpool RAS8244KQ0
Whirlpool RAS8244KQ1 Automatic Washer
Whirlpool RAS8244KQ2 Automatic Washer
Whirlpool RAS8244LQ0 Automatic Washer
Whirlpool RAS8244LQ1 Automatic Washer
Whirlpool RAS8245EN0
Whirlpool RAS8245EN1
Whirlpool RAS8245EQ0
Whirlpool RAS8245EQ1
Whirlpool RAS8245EW0
Whirlpool RAS8245EW1
Whirlpool RAS8333PQ0 Automatic Washer
Whirlpool RAS8333PQ1 Automatic Washer
Whirlpool RAS8333RQ0 Automatic Washer
Whirlpool RAS8333RQ1 Automatic Washer
Whirlpool RAS8333RQ3 Automatic Washer
Whirlpool RAS8333RQ4 Automatic Washer
Whirlpool RAS8445JQ0
Whirlpool RAS8445KQ0
Maytag RAX1000AXW Misc / Accessory
Maytag RAX1000CXB Misc / Accessory
Maytag RAX2000AXW Misc / Accessory
Maytag RAX2000CXB Misc / Accessory
Maytag RAX3000DXX Misc / Accessory
Maytag RAX33 Misc / Accessory
Maytag RAX3300CXX Misc / Accessory
Maytag RAX34 Misc / Accessory
Maytag RAX36 Misc / Accessory
Maytag RAX3600CXX Misc / Accessory
Whirlpool RAX4232JQ0
Whirlpool RAX4232KQ0
Whirlpool RAX4232KQ1 Automatic Washer
Whirlpool RAX4232PQ0 Automatic Washer
Whirlpool RAX4232PQ1 Automatic Washer
Whirlpool RAX4232RQ0 Automatic Washer
Whirlpool RAX4232RQ1 Automatic Washer
Whirlpool RAX4232RQ3 Automatic Washer
Whirlpool RAX4232RQ4 Automatic Washer
Whirlpool RAX4233PQ0 Automatic Washer
Maytag RAX5000AXB Misc / Accessory
Maytag RAX5000CXB Misc / Accessory
Maytag RAX5100AXB Misc / Accessory
Whirlpool RAX5133AG0
Whirlpool RAX5133AL0
Whirlpool RAX5133AL1
Whirlpool RAX5133AW0
Whirlpool RAX5133AW1
Maytag RAX5200AXB Misc / Accessory
Maytag RAX5200CXB Misc / Accessory
Maytag RAX5300AXB Misc / Accessory
Maytag RAX5400AXB Misc / Accessory
Maytag RAX5500AXB Misc / Accessory
Maytag RAX5500CXB Misc / Accessory
Maytag RAX5600AXB Misc / Accessory
Maytag RAX5700AXB Misc / Accessory
Maytag RAX5700CXB Misc / Accessory
Whirlpool RAX6144EN0
Whirlpool RAX6144EN1
Whirlpool RAX6144EQ0
Whirlpool RAX6144EQ1
Whirlpool RAX6144EW0
Whirlpool RAX6144EW1
Whirlpool RAX7244EN0
Whirlpool RAX7244EN1
Whirlpool RAX7244EQ0
Whirlpool RAX7244EQ1
Whirlpool RAX7244EW0
  #2 (permalink)
Old 02-21-2008, 12:45 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the cabinet according to these instructions and check the motor plug and wires.
Post your findings.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 02-22-2008, 10:06 AM
Junior Member
Default Motor connections ok
Gene thank you for your response. I check the motor connections as you suggest , and all connections were tight. I completely disasembled the washer ( took off water pump, motor and gear case ). I found out that the Motor drive coupling is broken. I tried to turn the shaft that the couplin connects to after I removed the motor but it would only turn about 1/4 of the way around in both directions. I tried to take the gear case apart by taking all the bolts out and prying apart but was not successful. The shalf and gears turned, unlike before where it would not budge. Could the gears be bad or could it be bad breaks? If the gears are bad, how can I remedy this ? Mod. # RAK2751KQO. Thank you in advance.
oogp1
  #4 (permalink)
Old 02-22-2008, 02:04 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If the gear case shaft is not turning in both ways - the gear case is bad and not the breaks.
I do not think it is a good idea to rebuild the gear case. There are no repair manuals for such job, hard to find parts and it's not worth money wise.
Replace the gear case and the coupling. Inspect the clutch and replace it too if it looks suspicious.
- The part number for the gear case is AP3096209
- The part number for the motor coupling is AP3961972
- The part number for the clutch is AP3094537
Here are the break down diagrams for the Roper washer Model RAK2751KQ0
__________________
  #5 (permalink)
Old 02-22-2008, 02:22 PM
Junior Member
Default Thank you.
You have been a great help. Thank you. Will inspect and replace as needed. Thanks again.
oogp1
  #6 (permalink)
Old 02-22-2008, 02:39 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Keep me updated, please.
__________________
  #7 (permalink)
Old 02-22-2008, 05:35 PM
Junior Member
Default Parts have been ordered.
Again thanks so much. I have ordered the parts and am awaiting delivery.
Will update you when it is re-assembled.
oogp1
  #8 (permalink)
Old 02-27-2008, 12:29 PM
Junior Member
Default Washer working
Hello Gene ,I received the parts (gear case and coupling ) and have just completed instalation. Machine is working but there is a knocking noise when the machine is in the wash cycle. I cycles fine , but it makes a knocking noise about every half a second when washing. Could it be that that pan type disk that the clip washer sits in needed to be greesed ? Thanks again for your help and I awaits your response.
oogp1
  #9 (permalink)
Old 02-28-2008, 11:36 AM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Take it apart and reassemble to insure proper installation.
If it would not help, then the gears case is defective and has to be exchanged under the part warranty.
__________________
  #10 (permalink)
Old 03-04-2008, 03:28 PM
Junior Member
Default Still knocking after re-assembled
Hello Gene, I took the machine apart and assembled it again but I have the same problem. I will have to return the gearcase for another one. Thanks again and I will let you know the outcome.
oogp1
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Won't Agitate MOSQUITO BITE Washer Repair 17 01-15-2010 05:30 AM
stackable washer dryer: washer will not agitate jennypatterson Dryer Repair 0 03-04-2009 11:08 AM
Washer does not agitate wackypackages Washer Repair 2 12-01-2008 03:55 PM
GE washer won't agitate lisav31 Washer Repair 8 07-29-2008 01:40 PM
Washer doesn't agitate dpuccetti Washer Repair 1 04-29-2008 02:00 AM
