joeblowsky
#1 Posted : Monday, March 16, 2015 12:10:39 PM(UTC)
joeblowsky
Our washer is leaking during the drain cycle. It appears to be leaking from the bottom of the tub. Could this be O-rings? My question is whether it is cost effective to consider repair.
sidfink43
#2 Posted : Tuesday, March 17, 2015 4:28:52 PM(UTC)
sidfink43
The way to be certain is to remove the cabinet and jumper the lid switch and operate the machine. This way you should be able to determine where the leak is coming from. Many times it will be at the pump, which is an easy repair. Since it is not leaking during basic operations this suggest the pump or hoses.
If it is from the center of the tub it is likely a seal and now you have to worry if water got into the transmission.
You can repair the seal, a lot more work but these are good basic models and well worth keeping.
Maytag washer leaks on power wash cycle (Washer Repair)
by homeland1984 8/1/2020 8:44:37 AM(UTC)
Maytag Washer leaks at bottom tub seal (Washer Repair)
by Stilltrying 6/22/2015 5:52:31 PM(UTC)
Maytag washer leaking (Washer Repair)
by kpks26 2/5/2014 1:16:48 PM(UTC)
Maytag Washer Leaking (Washer Repair)
by scottlassy 12/11/2012 7:46:32 PM(UTC)
Maytag Washer Leak repaired, but resulted in loss of spin (Washer Repair)
by Repair Gone Wrong 2/21/2012 11:21:14 AM(UTC)
by kaclark7 2/20/2012 5:03:39 PM(UTC)
Maytag Washer leaks (Washer Repair)
by A00446849 2/20/2012 9:31:31 AM(UTC)
Maytag Washer leaks on side of drain hose (Washer Repair)
by della 12/17/2011 10:34:04 PM(UTC)
maytag washer leaks (Washer Repair)
by kramler92 12/7/2011 4:47:43 PM(UTC)
Maytag Washer Leaking Water into Tub (Washer Repair)
by mightypasta 11/21/2011 8:55:22 AM(UTC)
Maytag washer leak at tripod bolt (Washer Repair)
by rrando 5/19/2011 5:43:10 AM(UTC)
Another Maytag Washer leaky tub parts question (Washer Repair)
by sbracer 2/22/2011 1:40:18 PM(UTC)
Maytag Washer leaks at bottom (Washer Repair)
by ronf 10/23/2010 6:07:28 AM(UTC)
Maytag washer leaks on the bottoom (Washer Repair)
by Bummer plumber 9/9/2010 7:56:24 AM(UTC)
maytag washer leaking and overflowing (Washer Repair)
by bennettelliott 9/4/2010 11:02:54 AM(UTC)
