I had a proximity lightning strike. House was not hit but a few breakers did their thing. Some house items no longer work, including this washer.
I can set up any level of service and press start. Everything lights up correctly, washer sits there for a bit and then lights out into pause mode.
I cannot find the instructions on how to get into diagnostic mode or how to read the errors. The Use and Care Manual does not address this that I can find. Any help in that arena would be appreciated!
I set the system to spin only, started, cancelled and then held Options & Start button down until lights started to blink. I am not sure this is correct procedure for this machine. Error code E6E. No idea what that means.
Clothes getting stinky. All comments appreciated.
Thanks Jim
