Have a Whirlpool Duet Model WFW9470WW01 Front loader washer 3yrs old.
Washer stopped midspin cycle and flashed an F26 code. Pressed cancel button and held for 3 seconds. Power shut down and door unlocked. Took out clothes and closed door. Pressed power button now flashed F70 code. Unplugged machine from power source and plugged back in to reset. When pressing power button now get four beeps and no lights on user control panel. Unable to run diagnostics, drum can be turned by hand it is not locked. Checked all connections and wire harness, all okay. Should I replace both user interface board and motor control board together?:confused:
