I got a washer and it stopped working because it got filled up with water all the way to the line with no clothes in it. I tried truning it on and it wouldn't work i took out water it started working now. After I drained i put towels in and filled up to large load and it filled up but wouln't agitate or spin or drain. I have changed the timer, lid switch, clutch and motor. I still get the sound like if a heater is warming up and the motor heats up along with a bad smell. I don't know what else to change. Its a year old. Pump and motor coupling are intact nothing wrong with it. Please help me I don't know what to do. Any suggestions would be helpful. Thanks
