I was helped by your experts on a code that NO ONE knew what it was. And I mean no one. When the tech came out to preform a service call he didn't even open up the washer to find the problem. Well I am very mechanically inclined so I did. I found a wire going to the door interrupt switch. I just finally recently replaced it. But now I'm getting a code of FL in capital letters. The machine does turn on, I hear a couple of clicks in main board that look like soleniods, then I get the code. What is this telling me? I bought the door switch part from you guys. Thanks in advance for your help.
Mike
