I Had Some Rugs In The Washer And It Stop Between The Run. I Try To Start It Back Up But Didnt Do Anything. Then I Had To Get The Water By Using A Bucket. Because It Would Not Drain Out So Please Give Me Info To Fix It.
Hi, Could have plugged up the drain pump or maybe have a bad lid switch. Drain Pump Part number: 3363394
